Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree1132Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 01-30-2013, 05:12 AM
Default Tamiya TT02 Thread
So Tamiya has announced the TT02 at the 2013 toy fair. Pics in my link here.
I will have the spec sheet typed up in a few minutes
New chassis layout
UPDATE
Editable set-up sheet.
https://www.thercracer.com/2022/04/t...p-and.html?m=0
madjack and Phat-Boy like this.
Last edited by Qatmix; 04-17-2022 at 03:05 PM. Reason: Edited title of thread down to requests
Qatmix is offline
Old 01-30-2013, 06:52 AM
Pretty underwhelming, but i kinda like it
http://www.rc-news.de/01/2013/spielw...s+der+RC-Szene!)
TubOLard is offline
Old 01-30-2013, 06:56 AM
mkiiina's Avatar
Trader Rating: 71 (100%+)
What were you expecting? Graphite, carbon,and al parts everywhere? The TT line has always been geared more to the lower/mid market segment.
mkiiina is offline
Old 01-30-2013, 06:57 AM
looks pretty nice , will hold off buying a TT01r type E then haha
sidecarphil1 is offline
Old 01-30-2013, 09:51 AM
Finally, here are some pictures of the new TT-02
YeshuaGriffin likes this.
addicted2blue is offline
Old 01-31-2013, 09:49 PM
sporadicidiocy's Avatar
TBH I am more excited over that 458 Italia body than the car itself.
sporadicidiocy is offline
Old 02-01-2013, 06:36 AM
Well, I was expecting at least steel dogbones, proper friction dampers and C-hub-type suspension.. TL-01 was also low cost and it had these basic things..
Some low-cost chassis with same or even lower price have FRP parts, aluminium motor holders and oil dampers... Why TT doesn't?
Papi is online now
Old 02-01-2013, 06:52 AM
DarthRacer's Avatar
If you convert the price listed on that German site, they say the price is $230.
DarthRacer is offline
Old 02-01-2013, 01:41 PM
but i read on the german website it is coming with a ball diff , just as we all swap back to gear diffs hahaha
Old 02-01-2013, 07:52 PM
ruebiracer's Avatar
No ball diffs, Diffs are carryover TT01.
More interesting is the shorter prop with longer front gear shaft.
Receiver box is a nice idea, but who will mount the ESC then above the Servo?
Not me for sure...
Nevertheless, very important car for Tamiya...
BR,
Matthias
ruebiracer is offline
Old 02-01-2013, 08:11 PM
superspeed's Avatar
Want to see the specs on tt02, specifically the weight comparing with tt01e. The chassis has rally/water resistant in mind plus lipo packs as well.
superspeed is offline
Old 02-02-2013, 05:29 AM
cartix's Avatar
Trader Rating: 36 (100%+)
The Ferrari body is sweet!
cartix is offline
Old 02-02-2013, 10:02 AM
valk's Avatar
Trader Rating: 13 (100%+)
not bad for the low bux, but id probably get a sakura for $100, or xv01 for $200. wasnt impressed with the tt01 to work on, even if it is supposed to be a cheap entry level broad spectrum chassis. I do not understand buying low and spending a ton of money on upgrades when you can just buy the better car from the start.
Revolter22 likes this.
valk is offline
Old 02-02-2013, 01:47 PM
buy it just for the fun limited mod class , we here have a TT01 class with little hop ups allowed and fixed gearing and that is the greatest class i have seen
this will be my next chassis if they bring out the R version and it is allowed in our TT01 class next winter ;-)
Old 02-08-2013, 02:01 PM
The car is good,but they really need to start giving oil shocks with their kits.step screw need to be remove and ball joints supplied.decent low cost racer.
pranash07 is offline
